Robotic Welding in the Automotive Industry
Time and cost optimized
production processes
Challenge
Modern vehicles needs to meet increasingly strict exhaust emission regulations, but at the same time customers expect more and more safety and comfort features. The automotive and supplier industry therefore relies on lightweight concepts, and light metals such as aluminum and magnesium, as well as high-strength and super-high-strength steels, are becoming increasingly important as materials.
This also means that welding technology is facing new challenges, and requires innovative solutions. Cost effectiveness is also crucial in the automotive industry, and in order to keep up with international competition, manufacturers and suppliers need to make their production processes as efficient as possible in terms of time and costs.
Partner in the Automotive Industry
Fronius has been a reliable partner of the automotive industry for many years. Together, we develop tailor-made solutions for your welding challenges using high-quality products and outstanding service. No matter whether you are dealing with robotic welding of exhaust systems, bodywork (body in white) or chassis components, you can rely on our experience and our know-how.
Quality
QUALITY
  • First class products according to the highest industry standards
  • Outstanding service from highly trained specialists
  • Worldwide support directly on the customer’s premises
Economy
COST EFFECTIVENESS
  • Technology and innovation leader in welding technology
  • Professional training for your employees
  • Comprehensive knowledge of the automotive and supplier industry
Know-how
KNOW-HOW
  • Time and cost optimized production processes
  • Seamless integration into the production process
  • Constant new development and further development of efficient welding processes
Good relations
GOOD RELATIONSHIPS
  • 25 years of experience in the automotive industry
  • Long-term partnerships and reliable cooperation with customers around the world
QUESTIONS ON WELDING SOLUTIONS FOR THE AUTOMOTIVE INDUSTRY?
Mobile phone, iPad, laptop and screen
Production Monitoring with WeldCube.
Weldcube
Save time and money with WELDCUBE:
  • Access welding data of up to 50 power sources centrally irrespective of the device, and analyze data at the touch of a button
  • Create and manage jobs centrally and distribute to the power sources
  • Optimize costs with simple analysis of consumption of gas and filler metals
  • Call up data quickly when servicing is needed, and therefore reduce downtimes
  • Continuous data documentation for quality assurance and to comply with standards
Read more about the subject
System solutions for the automotive industry
System Solutions for the Automotive Industry
Body in White
Whether steel, aluminium or mixed applications.
Fronius offers the optimum welding process.
Challenge
  • Practically spatter-free welding and brazing on galvanised steel
  • Low distortion due to optimised heat input
  • Low porosity
  • Stable arc
  • Optimum penetration
  • High welding speeds
Solution
TPS/i PMC/CMT
LaserHybrid
Challenge
  • Practically spatter-free welding of hot pressed components
  • Lower heat input (up to -50%) than with conventional gas metal arc welding
Solution
TPS/i PMC/CMT
LaserHybrid
Challenge
  • Fast brazing (up to 3 m/min)
  • Lower heat input
  • Flat and clean weld seam
  • Best weld seam appearance
  • Up to 60% less shielding gas
  • Spatter-free
Solution
TPS/i PMC/CMT
LaserHybrid
Challenge
  • High stability of the arc
  • Lowest heat input
  • Steel-aluminium joints possible
  • Minimal spattering
  • High gap-bridging ability
Solution
TPS/i PMC/CMT
LaserHybrid
Welding Challenges
  • Joining different materials (Steel-aluminium joints possible)
  • Lowest heat input and low distortion
  • Spatter-free welding
EXHAUST GAS SYSTEMS
Exhaust gas systems have developed into very complex systems. To reduce weight, increasingly thin materials are used.
Material: ferritic chrome steel
Challenge
  • High component tolerance
Solution
TPS/i PMC / LSC
Material: steel
Challenge
  • No spatter
  • Stable arc
  • High Welding Speed
Solution
TPS/i CMT
Challenge
  • No spatter
  • Stable arc
Solution
TPS/i CMT
Challenge
  • Good penetration
  • Good gap-bridging ability
Solution
TPS/i CMT
Welding challenges
  • Welding very thin materials
  • Joining materials of different thicknesses (flange)
  • Multiple sheet joints
  • High component tolerances
  • Damage to sensitive parts such as catalytic converters or particle filters by welding spatter
  • Cost effectiveness in production, large quantities
CHASSIS
Chassis components are usually safety-related components that require weld seams of the highest quality.
Material: steel
Challenge
  • Continuous root formation
Solution
TPS/i PMC
Material: steel
Challenge
  • Good penetration
  • Less spatter
Solution
TPS/i PMC
Material: aluminium
Challenge
  • Low heat input
Solution
LaserHybrid
Material: steel
Challenge
  • Less spatter
Solution
TPS/I PMC
Welding Challenges
  • Geringe Porosität bei Schweißnähten
  • Gute Spaltüberbrückbarkeit
  • Wenig Wärmeeintrag
  • Kein Verzug und hohe Güte bei hoch- und höchstfesten Stählen
  • Perfekte Zündung und Endkrater
  • Wirtschaftlichkeit in der Produktion
INTERIOR (SEATS, CROSS CAR BEAM)
Other materials, such as high-strength and super-high-strength steels, are often built into the interior of a vehicle. Fine mechanisms require welding with very low spatter.
Material: steel
Challenge
  • Low heat input
  • Less spatter
  • Thick/thin joints
Solution
TPS/i CMT
Material: steel
Challenge
  • Short weld seams
  • Stable ignition
  • Good penetration
Solution
TPS/i PMC
Material: steel
Challenge
  • No spatter
  • Stable arc
  • Short weld seams
  • Low heat input
Solution
TPS/i CMT
Welding challenges
  • Very thin materials
  • Mechanisms sensitive to spatter
  • High-strength and super-high-strength steels
  • Very short weld seams
  • Consistent quality
  • Different material thicknesses
Benefit from Our Services
Welding settings
Increase productivity and performance
We support you in the startup phase of your production process by providing production monitoring. Due to tailor-made and quick integration of our products, you benefit from optimized cycle times, avoid reworking and the system will be easy to use.
Expert know-how for your employees
To ensure that production is top quality in all countries, it is essential that all employees have the same level of knowledge, which is achieved through instruction, seminars and training.
Make optimum use of resources
With our years of experience in the automotive industry, we help you to optimize your production processes and parameter settings.
Reduction in downtime
We take over the servicing and maintenance of your welding systems for you and help you to avoid downtimes and save personnel costs as a result.
Let´s get connected.
