Aluminium
Aluminum Welding
Stable Connections, Lightweight
Challenge of Aluminum Welding
Alongside steel, aluminum is the most widely used construction material. Its biggest advantage is that it is just as strong but only around half as heavy. The use of aluminum is therefore preferred for lightweight constructions.
Interesting Facts About Aluminum
Welding of aluminium
Pure aluminum (Al99.5) is not very strong. However, it is used as the basis for alloys with a strength that matches up to steel.
Welding aluminum is particularly difficult because the material is surrounded by an oxide layer. This only melts at around 2015 degrees Celsius, while aluminum itself melts at around 650 degrees depending on the alloy. If the oxide layer were to be melted in the conventional manner then the aluminum would run away, and welding would be impossible. It is therefore necessary to destroy or displace the oxide.
Magnesium, manganese, copper, silicon and aluminium
What alloys of aluminum are there?
The properties of pure aluminum can be changed using alloys. For example, adding magnesium considerably increases the strength of the material.
The most important components of aluminum alloys and their properties are:
  • Magnesium (Mg)
    0.3–7% higher strength, finer grain size
  • Manganese (Mn)
    0.3–1.2% better corrosion resistance, higher strength
  • Copper (Cu)
    roughly 5% higher strength, lower corrosion resistance, important for hardening capacity
  • Silicon (Si)
    12% for casting, reduces the melting point to 577°C, however with coarse grains
Thumps up
Advantages
  • Very light but strong
  • Corrosion resistant
  • Temperature resistant
  • Not sensitive to UV radiation
Thumps down
Disadvantages
  • Expensive parent material
  • Difficult to weld
Professional Power Sources for Aluminum Welding
TPSi-320i
TPS 320i
  • Tick
    MIG/MAG welding system
  • Tick
    Integrated data documentation
  • Tick
    Intuitive touch display
Find out more about TPS 320i
TransSteel-2200
TransSteel 2200
  • Tick
    Multiprocess system: MIG/MAG, TIG, manual metal arc welding
  • Tick
    Portable and light for mobile use
  • Tick
    Intuitive operation and easy menu navigation
Find out more about TransSteel 2200
MagicWave-230i
MagicWave 230i
  • Tick
    Alternating current TIG welding system from the new generation
  • Tick
    Intuitive menu navigation
  • Tick
    Can be expanded with optional function package
Find out more about MagicWave 230i
Let´s get connected.
